Charlie_2_10323
May 14, 2009Nimbostratus
Rewriting Host, Uri and respond
Hi
We try to write an iRule to rewrite hostname, and uri bevor send it to Server and rewrite back for respond to client.
There are multiple uri,s to rewrite but one hostname.
So that it does not become simple, the blo.server.com is not behind big-ip it is a Server im Internet, which we will play middlemen.
Check host/uri (set to lowercase)
switch "[string tolower [HTTP::host][HTTP::uri]]" {
"www.client.com/rk/" {
HTTP::header replace Host "blo.server.com"
HTTP::uri "/rk/index.php"
set target_pool "blo.server"
pool blo.server
"www.clinet.ch/rk/xml.php" {
Rewrite host/URI
HTTP::uri "/rk/xmlrpc.php"
pool blo.server
when HTTP_RESPONSE {
if { $target_pool == "blo.server" } {
set location [HTTP::header value Location]
log local0.info "Server-RESPONS"
rewrite the location header
HTTP::header replace Location [string map {"blo.server.com" "www.client.com"} [HTTP::header Location]]
Does someone have idea?
Regards
Charlie
