Squeak's avatar
Squeak
Icon for Cirrus rankCirrus
Dec 02, 2020
Rewrite shortname in response
I´ve a site behind an apm, "www.company.com". The site have links that contains shortnames "asd" and I need to add the domain part to the shortname in the http response, like this "asd.company.com". I tried to write an irule but it looks like that the APM aren´t compatible with the stream profile.
Is it possible to fix this?
         #Disable the stream filter for requests
        STREAM::disable
         #Remove this header to prevent server from compression response
        HTTP::header remove Accept-Encoding
    when HTTP_RESPONSE {
        set internal_host "asd"
        set external_host "asd.company.com"
         #Rewrite the Location header for redirects
        if { [HTTP::header exists Location] }{
            HTTP::header replace Location [string map "$internal_host $external_host" [HTTP::header Location]]
         #Rewrite the response content using a stream profile if it is text
        if { [HTTP::header Content-Type] contains "text" } {
         #Set the stream expression with the find/replace strings
            STREAM::expression "@$internal_host@$external_host@"
         #Enable the stream filter
            STREAM::enable
  • Hi  ,
    I dont think its possible. APM with Stream profile. You can try this though - VS behind VS.
    Put your APM on VS1 and let that pass the traffic to another VS2, in VS2 you can apply your stream profile & do your required changes.
    Please test and update us if possible.
