02-Sep-2020 17:13
Hi I am trying to implement a apache rewrite config into a F5 VS/iRule
I need to rewrite a https request to node IP and Port. I would also like to have a switch to rewrite to same node ip but different port based on the FQDN.
Something like
when
http request on dns1.domain.com rewrite to http://node:port1
http request on dns1.domain.com/URI-X rewrite to http://node:port2
http request on dns2.domain.com rewrite to http://node:port3
http request on dns2.domain.com/URI-X rewrite to http://node:port4
http request on dns3.domain.com rewrite to http://node:port5
http request on dns3.domain.com/URI-X rewrite to http://node:port6
While I am figuring it out will be glad to get some idea's/irules 🙂
Cheers,
Rony
02-Sep-2020 19:59
ok so the following irule works in a sense it matches fqdn and redirects to instructed node and port.. thats working perfect.
switch -glob [HTTP::host] {
fqdn1 {
HTTP::header replace Host "????" # < --- I want to replace the IP of node with the fqdn to verify certificate
HTTP::redirect http://node:port1[HTTP::uri]
if { [HTTP::uri] starts_with "/uri-X" } { HTTP::redirect http://node:port2[HTTP::uri] }
fqdn2 {
HTTP::redirect http://node:port3[HTTP::uri]
if { [HTTP::uri] starts_with "/uri-X" } { HTTP::redirect http://node:port4[HTTP::uri] }
fqdn3 {
HTTP::header replace Host "???"
HTTP::redirect http://node:port5[HTTP::uri]
if { [HTTP::uri] starts_with "/uri-X" } { HTTP::redirect http://node:port6[HTTP::uri] }
But... the rewrite of host is not working. I tried putting in node IP, the fqdn etc but no dice... if this somehow works i will be happy 🙂
what am I missing??
