Technical Forum
Reverse Proxy
cyberS
Hello all,
I am new to this site and set of products and am just trying to understand if NGINX Reverse proxy is a solution that will solve my issue and therefore worth exploring.
In brief, we have a system called Mendix which is a cloud system hosted in AWS.  That system needs to connect to our on-premise SAP server webserver, via port 44300, which will then ask for credentials from the SAP side.  I have Azure Application Proxy setup which almost works, but Mendix appears to have issues sending multiple credentials and types of credentials using that system.  Would the NGINX work in a similar way?
We only really need to allow the Mendix cloud app to have access, so would need a way to authenticate just that to gain a connection to the SAP server, which it would then need to authenticate against - this I believe is achievable if using only one type of authentication from the Mendix point of view.
This is hard to explain, so would be open to a conversation.
Look forward to any responses.
CS
2 REPLIES 2
Better maybe check with the F5 sales engineers about this and test the trial versions yourself if they do the job and have no issues:
https://www.nginx.com/free-trial-request/
LiefZimmerman
Community Manager
Community Manager
@cyberS - If your post was solved it would be helpful to the community to select *Accept As Solution*.
This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
