Return a text string
We are looking to re-direct Microsoft Network Connect Service queries (http://www.msftncsi.com/ncsi.txt) to a virtual server, and serve up the string ourselves via an F5 iRule or other method.
The text file contains the following line:
Microsoft NCSI
Is this possible? We are exceeding our Websense License count by this simple connect script, as computers which are not used to connect to the internet still run up our license count by connecting to this website.
Thanks,
Mark
- nathe
Cirrocumulus
Mark
What springs to mind....if you've got v11.1 of course is iFiles. You could import the ncsi.txt file and set an iRule to reference this when it receives a http request for msftncsi.com
Hope this helps,
Nathan - nathe
Cirrocumulus
Mark
See https://devcentral.f5.com/tutorials/tech-tips/v111-ndashexternal-file-access-from-irules-via-ifiles
HTH
Nathan - What_Lies_Bene1
This is definitely possible. I'll post an iRule shortly. - What_Lies_Bene1
Here you go;
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] ends_with "ncsi.txt" } { HTTP::respond 200 content "Microsoft NCSI" } }--Corrected as directed below
- etem055
where should be define this file?
ncsi.txt
- nitass
Employee
i just corrected bracket and operator.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { if { [string tolower [HTTP::path]] ends_with "ncsi.txt" } { HTTP::respond 200 content "Microsoft NCSI" noserver Content-Type "text/html" Connection "Close" } } } [root@ve10:Active] config curl -i http://172.28.19.79/ncsi.txt HTTP/1.0 200 OK Content-Type: text/html Connection: close Content-Length: 14 Microsoft NCSI - Mohamed_Lrhazi
Altocumulus
Does not sound very kosher though. for example, why block that URI, if in fact you think they should not be allowed to use any Internet service at all?
Anyways, so you can manage for all http traffic from these client to come to your F5s? how do you do that? F5 LTM is the gateway?
In order to use an iRule like suggested, you would need a virtual server listening on an IP that those clients would connect to... you could try and just make that IP the actual Microsoft IP address.. is there only one? what if it changes?
If you can control the clients, it might be simpler to update their /etc/hosts to point the DNS name to loopback. - Mohamed_Lrhazi
Altocumulus
Please ignore my kosherness remark and accept my apologies. that was wrong and wrong.
Thanks,
Mohamed. - What_Lies_Bene1
Thanks as ever nitass. I've corrected my post too just in case someone doesn't scroll down! - nathe
Cirrocumulus
Mark, looks like I was too keen to get a new feature in (relatively new anyway) and over complicated matters.
Thanks Steve / nitass - a lesson learned on keeping things simple ;-)
N - MGrift_57913
Thanks guys.
I can't segregate traffic based on ip - the desktop domain is one big DHCP VLAN. I can however answer a DNS call with an IP of my choosing, which is far simpler in my situation.
This part is precisely what I was looking to do:
rule myrule {
I tried this a dozen different ways which didn't work, but never with the "text/html" field. I'll plug this one in shortly, and verify results.
