Technical Forum
Restricting traffic between Vlans.
scarville
We have an F5 servicing our DMZ. It hosts the external IPs and acts a router for the DMZ servers.
                                        +--- [ VLAN_2110 ]
[ Internet ] ---- [ F/W ] ---- [ F5 ] --+
                                        +--- [ VLAN_2310 ]
Recently a new requirement has emerged to keep one group of Vlans from talking to another group. A for instance would be that VLAN_2110 and VLAN_2310 in the above sketch would not be allowed to talk to each other.
Can the F5 do this?
3 REPLIES 3
Hello @scarville,
From my perspective, the easiest way to achieve this is to configure two reject VS to deny the traffic between those vlans.
1. Configure one reject VS listening on VLAN_2110 and use the IP range of VLAN_2310 as destination.
2. Configure one reject VS listening on VLAN_2310 and use the IP range of VLAN_2110 as destination.
Regards,
Dario.
CA_Valli
MVP
MVP
F5 is a default deny deivce, so inter-VLAN routing is denied out-of-the-box unless you explicitly allow it (using something like an IP forwarding Virtual Server).
To prevent clients in a VLAN from accessing Virtual Servers on the "Internet" side potentially leading to servers in the other VLAN, you can configure the VS to listen only on Internet VLAN. This is usually common practice.
If the requirement is to have completely dedicated VRF's as well, you might want to take a look at F5 Routing domain feature https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-routing-administration-11-...
