02-Apr-2021 10:48
My website that resides under BIG IP F5 can directly be opened making use of public IP. As my site is one to one NAT'd and and one application under one public IP it can directly be opened using public IP. I want to restrict making use of opening the site directly via the public IP and available only through domain. Please, do let me know if there is any way that I can achieve this .
Solved! Go to Solution.
03-Apr-2021 01:55
If you VIP hosts single domain then use this to whitelist it
switch [string tolower [HTTP::host]] {
"www.domain.com"
return
default {
reject
If VIP hosts multiple domains/SAN use below to whitelist all
"www.domain1.com" -
"www.domain2.com" -
"www.domain3.com"
return
default {
reject
02-Apr-2021 14:00
You can use iRule, LTM policy or ASM profile to reject the requests coming with IP as HOST header. Let me know if you need further help with any of it.
02-Apr-2021 20:19
thank you for the reply...can you share me the irule if possible ?
02-Apr-2021 20:25
tryin to use this irule without any success
03-Apr-2021 01:55
"www.domain.com"
return
default {
reject
"www.domain1.com" -
"www.domain2.com" -
"www.domain3.com"
return
default {
reject
03-Apr-2021 03:43
thanks ...working now
