Bernard_9303
Feb 26, 2009Response URL re-mapping
When I try to access my SharePoint server (newly setup) via F5. The correct URL response that the client should get should be from the F5 virtual server i.e. sharepoint.xxx.com.sg.
But I actually received the URL response from the SharePoint server i.e. xxx.xxx.xxx.xxx
I'm looking for a way to use iRules to re-map the URL response to the client so that my server IP is transparent to the client, all they should know is the F5 virtual server sharepoint.xxx.com.sg and not server ip xxx.xxx.xxx.xxx.
If they see the server ip xxx.xxx.xxx.xxx, they may just bypass F5 and access Sharepoint server directly.
I'm doing SSL offloading on the F5.
Thanks,
Bernard
