19-Feb-2020 23:27
I would like to configure my DNS box as a resolver. I have applied all the steps as described in the following link
except that I noticed that the GTM uses other public IP which I have not configured in the Root hits part knowing that I have specified two external public IPs that the GTM must consult to resolve. is there a way to tell the GTM does the resolution only from these two IP XXXXX YYYYY
21-Feb-2020 08:18
Hi Mahir,
Private Root Hint server IPs are configured when the network is completely isolated from public networks. For example, Military networks,classified networks etc.
For the networks connected to Public internet, there is no need for defining private root hint servers as public root hint servers do the job pretty well.
Here are the list of default Root Hint servers:
https://www.iana.org/domains/root/servers
Based on your problem description, I think, the DNS resolver you are building is not for air-gap or classified networks which are disjointed from public internet.
If that is true, you need not configure root hint servers and leave it blank so it uses public root servers as it should.
Moreover, when you query for a public domain name, and network is connected to public internet in any way, you can only get a Authoritative answer from a public source(IP) .
Let me know if it is not clear enough.
Regards,
Nag
21-Feb-2020 08:21
Additional resources:
23-Feb-2020 04:07
Hello NAG
thank you for your help and support. is there a way to configure my DNS resolver to use just one public ip for example 8.8.8.8 to respond to internal DNS queries.
today even if I configure my forwarded zone with 8.8.8.8 I still see that my GTM uses public root IP
best regards
Mahir
