RiverFish's avatar
RiverFish
5 years ago
Solved
Replace path in redirect
Expectations:
using the old hostname (oldhostname.com) will redirect to the new hostname (newhostname.com)
using / (nothing after .com) will redirect to /newpath
using /oldpath/foo will redirect to /newpath/foo
The issue is the last part. If you do something like this...
if { [string tolower [HTTP::uri]] starts_with "/oldpath" } {
    HTTP::redirect "/newpath[HTTP::uri]"
It grabs the oldpath, so it looks like this /newpath/oldpath. Please help if you can
  • Hello,
    You can try to re-create your iRule by referring below article.
    https://support.f5.com/csp/article/K48922683
  • Hello,
    • RiverFish's avatar
      RiverFish
      Mayur, we eventually found that article and were able to come up with the irule below which got us working. The switch statement is just some tweaks that are custom for our particular site. Thanks!
        if { [HTTP::host] contains "oldhostname.com" } {
          set newhost "newhostname.com"
          set newpath [string map {"/oldpath/" "/newpath/"} [HTTP::uri]]
          HTTP::redirect "https://$newhost$newpath"
          return
            switch [HTTP::uri] {
              "/oldpath" -
              "/oldpath/" -
              "/oldpath/login/" -
              "/newpath/login/" { HTTP::redirect "https://[HTTP::host]/newpath/login" }
              default {}
            return
