Technical Forum
Removing the webtop URL box from webpage.
Squeak
Cirrus
Cirrus
I´ve a webtop that are configured as a Portal Access type. When I access the backend server I can see that the bigip adds a small URL box, how do I remove it?
Running version 14.
1 REPLY 1
Hello Squeak.
Check this out.
https://support.f5.com/csp/article/K13593
https://support.f5.com/csp/article/K13592
Regards,
Dario.
Regards,
Dario.
