Remove offline nodes from a pool tmsh
Roy_Morris_3626
I use this command to remove all nodes from a pool but I have cases where I want to remove just the offline ones, anyone know the command please?
modify ltm pool [POOL_NAME] members delete {all}
Thanks!
1 REPLY 1
boneyard
MVP
MVP
i don't believe that exists. it being offline depends on the health monitor and the node delete command doesn't take that into account.
so just remove it manually per offline node based on its name.
