Ten_92952's avatar
Ten_92952
Jun 03, 2010
remoterole usage
The Bigip is using version BIG-IP 9.4.8 Build 396.1 Hotfix HF3
I have the BigIp set up to use TACACS for authentication and it works just fine as long as I have a user account set up on the BigIp.
I am trying to use the "remoterole" option so I can configure group level permissions.
We are using TACACS version 3.3 and I set the attribute value for timeout to 1000 so I could use it to identify the group
This is what I entered on the BigIP
bigpipe remoterole role info mygroupofusers { attribute "timeout=1000" line order 2000 role operator }
the ":remoterole list all" command shows the following
remoterole {
partition Common
partition Common
console disable
deny disable
line order 2K
role operator
user partition Common
but I cannot authenticate
Any ideas?
The other question is how do you use the remote role command to set up users with Administrator privelages?
I am having trouble with the partition command. Teh error meswsage says the admin user must have access to all partitions but it will not accept "partition all" in the remottole command
thanks
