Brian_Gibson_30's avatar
Brian_Gibson_30
Apr 03, 2019
relative addresses not allowed on SCP request
I have a set of lab load balancers running 14.1. Whenever I try to scp a file to or from that box I get an error saying "relative addresses not allowed" Any idea what this is all about? The same SCP works on our 13.X boxes.
  • Few questions:
    • Can you still SSH to the F5 via the IP address on 14.1?
    • Do you still have access to the Bash shell via SSH?
    • How are you authenticating, username/password or ssh key?
  • MarkB's avatar
    MarkB
    I hit this on a 13.1 box. I expect you found a workaround, but since it's not mentioned here, I'll add mine (for anyone else who searches on this issue)
    You just need to add a path to the SCP command.
    So instead of 'scp afile bigip:' use 'scp afile bigip:~' (for your home directory)
  • I know this is old but to help others, here is my workaround.
    Rather than using: "scp file.ucs remoteserver:"
    use the full path to the file you are sending "scp /var/local/ucs/file.ucs remoteserver:"
    Do this even if current working path is in the same directory as the file.
  • Hello,
    I am having the problem using version 16.1.2.2 on Viprion "vCMP Guest", when I try drag and drop via "winscp", I recived this same error "relative addresses not allowed".
    Workaround: To copy my files using winscp, I use right botton mouse > copy on file and rigth botton mouse  > paste on my "desktop".
    I hope that works with you too.
    • John's avatar
      John
      Thank you for the copy/paste workaround, works perfectly!
  • This bug is still not fixed? I got the error as well since years, but the copy/paste workaround from jhonny is working! Thx! 🙂
