redirect with variable uri
VS
Newbie to F5 working on my first irule and already stuck. I have an irule similar to below which works. But now need to modify it with part of the URI "123456" being variable and redirected to the corresponding value. Any suggestions would be greatly appreciated!
if { ([HTTP::host] contains "website1") and ([string tolower [HTTP::uri]] starts_with "/test1/download/?uri=123456&t=record&lang=ln_english&mbd=false") } {
HTTP::redirect ""http://website2.com/test/Record/123456/File/Document""
else { pool POOL1 }
1 ACCEPTED SOLUTION
Hello VS.
Try this.
when HTTP_REQUEST { set uri_param [URI::query [HTTP::uri] uri] if { ([HTTP::host] contains "website1") and ([string tolower [HTTP::uri]] starts_with "/hptrimwebclient/download/") } { HTTP::redirect "http://website2.com/CS/HPRMServiceApi/Record/$uri_param/File/Document" } else { pool POOL1 } }
Regards,
Dario.
Regards,
Dario.
4 REPLIES 4
Hello VS.
You need to clarify better what you want to achieve.
Some example would be nice.
Regards,
Dario.
Regards,
Dario.
Hi Dario!
I am trying to redirect :
http://website1/hptrimwebclient/download/?uri=123456&t=record&lang=ln_english&mbd=false
to:
http://website2.com/CS/HPRMServiceApi/Record/123456/File/Document
However 123456 above is a variable number and would need to be redirected to the corresponding URL with the same number. So that if the above example changes to:
http://website1/hptrimwebclient/download/?uri=987654&t=record&lang=ln_english&mbd=false
Then it would get redirected to:
http://website2.com/CS/HPRMServiceApi/Record/987654/File/Document
Thank you!
Hello VS.
Try this.
Regards,
Dario.
Regards,
Dario.
VS
Hi Dario,
The above works great! Thanks so much for the help!
