Technical Forum
Custom Alert Banner
Redirect iRule problem
tempsuli
Altostratus
Altostratus
Hello,
I would need to do the following with an iRule. Any ideas are appreciated! Basically I need to know how to retrieve the original host in the request and add it to the end in the redirect.
https://www.abc.com/xxx redirected to -> www.xyz.com/portal/dsds?=https://www.abc.com/xxx
Teemu
1 ACCEPTED SOLUTION
	HTTP::redirect https://www.xyz.com/portal/dsds?=https://[HTTP::host][HTTP::uri]
	# OR:
	# HTTP::respond 301 Location https://www.xyz.com/portal/dsds?=https://[HTTP::host][HTTP::uri]
Also, you can achieve the same with a local traffic policy.
3 REPLIES 3
	# OR:
tempsuli
Altostratus
Altostratus
Thanks! It was so simple : )
-teemu
Please mark the thread as solution provided if its resolved.
