05-Jun-2021 19:21
Dear Community
I have a VS Standard with a profile http that have two wildcard ssl for two domain *.abc.com and *.xyz.com.with a irule select the correct pool based on http:host, all work fine. but now, I have to do redirect from https://www.abc.com to https://www.xyz.com, when redirect this in the irule get a cert error on browser. I believe is not possible to do the redirect because the request is attended for the same VS and the ssl handshake.
I try to do a response location 301 but also not working.
Best regard.
