lipos_54863
May 18, 2009Nimbostratus
Receive String problem
I'm trying to create a regular monitor that would monitor a website with:
Send String: GET / HTTP/1.0
Receive String: Welcome Page
When I do telnet "IP of the Node" 80, I get text that is including "Welcome Page" string, but the monitor seems to be down.
When I use a Receive String of "div" the monitor goes up.
Is there something wrong with formatting of the Receive String for my request?
I guess the configuration should be pretty straightforward, but still I'm stuck.
I tried GET /Default.aspx HTTP/1.1 with similar recieve strings and still nothing.
Also, if I use my default monitor of:
Receive String: 200 OK
Everything works well, but I need to monitor some text from the website.
Any ideas?
