19-May-2022 11:21
I have a pair of r5600 appliance running F5OS. I went through the initial configuration and set the hostname to let say ABCD and the admin CLI prompt was set correctly to ABCD. But when I logged into the device as root, the linux hostname didn't change and was still at the default of "appliance-1.chassis.local" I have a few of these appliances and it is quite confusing as I can't tell which system I am on.
Question 1:Can I change it to match the hostname I set in the F5OS config?
Question2: Do I do change it by modifying /etc/hostname ?
Question 2: Will it affect anything?
26-May-2022 06:56
I am talking changing the hostname in F5OS linux prompt, not the F5-BIG-IP OS.
27-May-2022 01:11
Ah sorry, didn't pickup on that. Have you tried this...?
27-May-2022 08:10
Thanks for the reply iaine.
Sorry, I know this is confusing. But that's not it. The configs in the link can also be changed within the GUI.
I am talking about this one.
CentOS Linux 7 (Core)
Kernel 3.10.0-1160.25.1.F5.1.el7_8.x86_64 on an x86_64
appliance-1 login: root
Password:
Last login: Fri May 27 10:47:47 from localhost
[root@appliance-1 ~]# hostname
27-May-2022 08:19
Have you tried this?
Change the BIG-IP system host name (f5.com)
Pete
29-Aug-2022 12:33
I got the offical word from support and they said the hostname can't be change. They put in a feature request for furtue update. So just be carefull when you are working on multiple hosts at the same time.
29-Aug-2022 12:38
Oof. It shows up in remote syslog too, which I guess isn't the end of the world because we can still filter logs by source IP. All my syslog output is in UTC too, despite F5OS being configured as Eastern Time... all kinds of fun.
