AlexS_yb's avatar
AlexS_yb
Aug 22, 2022
QUIC - HTTP/3 + F5 LTM + APM + WAF
Hi
looks to me like HTTP/3 is coming to all, I like some of the features. But how do I get http/3 /quic and LTM + APM + WAF
I get that http/2 is available and LTM only. I presume http/3 will be roughly the same.
I'm guessing but if I want to could I
create a VS with http3 and all it does it then reverse proxy to another VS and on the second VS I can do APM / WAF.
internet -> VS / HTTP3 / LTM -> VS / HTTP1.1 / LTM /APM / WAF -> resource pool
does that work does the second VS see the client ip - will APM work in that scenario ?
When it http/3 going to be fully supported LTM/APM/WAF ?
    • AlexS_yb's avatar
      AlexS_yb
      But no APM ?
      so do i still need
  • Hi,
    looking for the same here.
    Try to enable QUIC - HTTP/3 on on LTM based on K60235402 with attached Access Policy / Access Profile and Connectivity Profile.
    But got an:
    01070734:3: Configuration error: Profile(s) found on <...>_vs that are not allowed: Only (TCP Profile, UDP Profile, QUIC Profile, ClientSSL Profile, ServerSSL Profile, HTTP Profile, HTTP2 Profile, HTTP3 Profile, HTTP Compression Profile, Application Visibility and Reporting Profile, DNS Profile, DOH Proxy Profile, profile statistics, Protection Profile, Bot Defense Profile, Bot Defense ASM Profile, Web Security Profile, HTTP Router Profile, Web Accelerator Profile, Request Logging Profile, TDR Profile)
    Running currently on TMOS 16.1.4.1
    Is QUIC - HTTP/3 with required HTTP MRF Router not supported on LTM with attached APM?
    Thanks in advance! ✌️
