mr_evil_116524's avatar
mr_evil_116524
May 19, 2015
Question about maintenance window and time
Hello All,
So I have an iRULE for schedule maintenance window in our F5. This works great except for some reason is it removing the leading zero from minute, please see the iRULE below:
     Change the following to set schedule
    set maintenance_start_time "2204";
    set maintenance_end_time "2206";
    set maintenance_start_day "Tuesday";
    set maintenance_end_day "Tuesday";
   Get time in seconds, formatted as day of week (%A) hour (%k) minute (%M)
    Use scan to save output as $cur_day $cur_hour $cur_minute
    scan [clock format [clock seconds] -format {%A %k %M}] {%s %d %d} cur_day cur_hour cur_minute
    scan [clock format [clock seconds] -format {%s}] {%d} cur_sec
    set cur_time ${cur_hour}${cur_minute}
    set cur_time_sec ${cur_sec}
     log local0. "\$cur_day: $cur_day, \$cur_hour: $cur_hour, \$cur_minute: $cur_minute, \$cur_time: $cur_time"
    log local0. "\$cur_time_sec : $cur_time_sec"
    if { ($cur_time >= $maintenance_start_time) && ($cur_time <= $maintenance_end_time) && ($cur_day >= $maintenance_start_day) && ($cur_day <= $maintenance_end_day) } {
             if { [HTTP::uri] ends_with "front_image_en.png" }
So right now I cannot schedule maintenance window say where min is 00 i.e. 1500 or 1400 however when I do 1510 it works as there is no leading zero infront of the 1.
Does anyone know how can I put in the leading zero.
When there is no leading zero this is what I see in the logs
May 19 22:22:45 info tmm3[20399]: Rule /Common/maintenance_window : $cur_day: Tuesday, $cur_hour: 22, $cur_minute: 22, $cur_time: 2222May 19 22:22:45 info tmm3[20399]: Rule /Common/maintenance_window : $cur_time_sec : 1432030965May 19 22:22:45 info tmm3[20399]: Rule /Common/maintenance_window : $cur_day: Tuesday, $cur_hour: 22, $cur_minute: 22, $cur_time: 2222May 19 22:22:45 info tmm3[20399]: Rule /Common/maintenance_window : $cur_time_sec : 1432030965
When there is a leading zero I see the following
May 19 22:06:28 info tmm2[20399]: Rule /Common/maintenance_window : $cur_day: Tuesday, $cur_hour: 22, $cur_minute: 6, $cur_time: 226 May 19 22:06:28 info tmm2[20399]: Rule /Common/maintenance_window : $cur_time_sec : 1432029988 May 19 22:06:28 info tmm2[20399]: Rule /Common/maintenance_window : $cur_day: Tuesday, $cur_hour: 22, $cur_minute: 6, $cur_time: 226 May 19 22:06:28 info tmm2[20399]: Rule /Common/maintenance_window : $cur_time_sec : 1432029988
  • I was helping on another time related thread and took some of the work here and modified. Hopefully this helps someone who has a maintenance window that crosses midnight.
    when RULE_INIT {
        set static::start_time 221500
        set static::end_time 001459
        set static::days [list "Wednesday" "Thursday"]
        #scan [clock format [clock seconds] -format {%A %H%M%S}] {%s %s} cur_day cur_time
        ### FOR TESTING PURPOSES ONLY ###
        #scan [clock format [clock scan "Wed Jan 20 22:14:59 CST 2021"] -format {%A %H%M%S}] {%s %s} cur_day cur_time
        #scan [clock format [clock scan "Wed Jan 20 22:15:00 CST 2021"] -format {%A %H%M%S}] {%s %s} cur_day cur_time
        #scan [clock format [clock scan "Thu Jan 21 00:14:59 CST 2021"] -format {%A %H%M%S}] {%s %s} cur_day cur_time
        #scan [clock format [clock scan "Thu Jan 21 00:15:00 CST 2021"] -format {%A %H%M%S}] {%s %s} cur_day cur_time
        ### END TESTING STRINGS ###
        if { !(($cur_day eq [lindex $static::days 0]) && ($cur_time >= $static::start_time)) &&
             !(($cur_day eq [lindex $static::days 1]) && ($cur_time <= $static::end_time)) } {
                 # NORMAL CONDITION
                 HTTP::respond 200 content "Situation: Normal. $cur_day, $cur_time "
            # MAINTENANCE CONDITION
            HTTP::respond 200 content "Situation: Maintenance. $cur_day, $cur_time "
