LTM Maintenance Window
Problem this snippet solves:
This iRule uses the STATS profile to manage an LTM maintenance page response during maintenance windows.
Implementation details here: https://devcentral.f5.com/articles/irule-maintenance-windows
Code :
set TITLE "iRule Maintenance Window Control"
set PROFILE_NAME "maintenance_window"
# Look for embedded commands to control the maintenance window.
switch -glob [string tolower [HTTP::uri]] {
"/enable*" {
# Extract the maintenance window day, start time, and end time from the URI.
# If not there, return an error message.
set params [split [HTTP::uri] "/"]
if { [llength $params] < 5 } {
HTTP::respond 200 content "
$TITLE
Usage: http://[HTTP::host]/enable/day_number/start_hour/end_hour
# Update the maintenance window values in the statistics profile.
STATS::set $PROFILE_NAME "day" [lindex $params 2]
STATS::set $PROFILE_NAME "start_time" [lindex $params 3]
STATS::set $PROFILE_NAME "end_time" [lindex $params 4]
$TITLE
Maintenance Window enabled
"/disable" {
# By zero'ing out the values in the statistics profile, the maintenance window is not enforced.
STATS::set $PROFILE_NAME "day" 0
STATS::set $PROFILE_NAME "start_time" 0
STATS::set $PROFILE_NAME "end_time" 0
$TITLE
Maintenance Window disabled
"/check" {
# Return the current time and the current settings for the maintenance window
set day [STATS::get $PROFILE_NAME "day"]
set start_time [STATS::get $PROFILE_NAME "start_time"]
set end_time [STATS::get $PROFILE_NAME "end_time"]
set l [split [clock format [clock seconds] -format {%u %H %M}] " "]
set cur_day [lindex $l 0]
set cur_time [expr [expr [lindex $l 1]*100] + [lindex $l 2]]
$TITLE
Current Date and time: $cur_day, $cur_time
Maintenance Window: $day, $start_time - $end_time
"/usage" {
# Usage instructions for the commands
$TITLE
Usage: http://[HTTP::host]/\[command\]
- /enable/day_of_week_number(1:mon-7:sun)/start_time(hhmm)/end_time(hhmm) - enable maintenance window.
- /disable - disable maintenance window.
- /check - check if in maintenance window.
- /usage - display this usage message
default {
# no secret command entered, so check the maintenance window
# Get the values from the statistics profile.
if { ($day ne 0) and ($start_time ne 0) and ($end_time ne 0) } {
# Use the TCL "clock" command to get the current time settings.
if { ($cur_day eq $day) &&
($cur_time >= $start_time) &&
($cur_time <= $end_time) } {
# The current time is in the maintenance window, so either issue a HTTP::redirect here to a
# prettied up page, or you can do as I've done here, and return a HTML response direction
# to the client.
$TITLE
This site is down for maintenance, please come back at $end_time ...
# Not in maintenance window, so allow connection to continue to application.
}Published Mar 18, 2015
Version 1.0CodeCentral_194
Joined May 04, 2019
