sbaron_111933's avatar
sbaron_111933
Jun 25, 2009
Query execution failed for data set 'GroupProperties' error for several reports
Seeing this error for several reports, including Virtual Servers by Bandwidth, Virtual Servers by Connection Count, and Unused Virtual Servers. From the SRS log:
w3wp!library!6!06/25/2009-10:46:27:: i INFO: Call to RenderFirst( '/F5_ManagementPack/F5.Report.TopVirtualServerByBandwidth' )
w3wp!processing!a!6/25/2009-10:46:27:: e ERROR: Throwing Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for data set 'GroupProperties'., ;
Info: Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for data set 'GroupProperties'. ---> System.Data.SqlClient.SqlException: Incorrect syntax near ','.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader(CommandBehavior behavior)
at Microsoft.ReportingServices.DataExtensions.SqlCommandWrapperExtension.ExecuteReader(CommandBehavior behavior)
at Microsoft.ReportingServices.ReportProcessing.ReportProcessing.RuntimeDataSetNode.RunDataSetQuery()
--- End of inner exception stack trace ---
w3wp!processing!a!6/25/2009-10:46:27:: e ERROR: An exception has occurred in data source 'GroupProperties'. Details: Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for data set 'GroupProperties'. ---> System.Data.SqlClient.SqlException: Incorrect syntax near ','.
at Microsoft.ReportingServices.ReportProcessing.ReportProcessing.RuntimeReportDataSetNode.FirstPassInit()
at Microsoft.ReportingServices.ReportProcessing.ReportProcessing.RuntimeDataSetNode.FirstPassProcess(Boolean& closeConnWhenFinish)
at Microsoft.ReportingServices.ReportProcessing.ReportProcessing.RuntimeReportDataSetNode.Process()
at Microsoft.ReportingServices.ReportProcessing.ReportProcessing.RuntimeDataSetNode.ProcessConcurrent(Object threadSet)
w3wp!processing!a!6/25/2009-10:46:27:: i INFO: Merge abort handler called for ID=-1. Aborting data sources ...
w3wp!dataextension!a!6/25/2009-10:46:27:: w WARN: CommandWrapper.Cancel not called, connection is not valid
w3wp!processing!6!6/25/2009-10:46:27:: e ERROR: Throwing Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing., ;
Info: Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for data set 'GroupProperties'. ---> System.Data.SqlClient.SqlException: Incorrect syntax near ','.
w3wp!processing!6!6/25/2009-10:46:27:: w WARN: Data source 'DataWarehouseMain': Report processing has been aborted.
w3wp!webserver!6!06/25/2009-10:46:27:: e ERROR: Reporting Services error Microsoft.ReportingServices.Diagnostics.Utilities.RSException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for data set 'GroupProperties'. ---> System.Data.SqlClient.SqlException: Incorrect syntax near ','.
