04-Jun-2020 04:55
We are trying to implement proxy protocol (for use with SAP Web Dispatcher) and have this irule:
when CLIENT_ACCEPTED {
set proxyheader "PROXY TCP[IP::version] [IP::remote_addr] [IP::local_addr] [TCP::remote_port] [TCP::local_port]\r\n"
when SERVER_CONNECTED {
TCP::respond $proxyheader
It's working perfectly fine, which we checked via tcpdump.
Problem is that we need Proxy protocol version 2 (binary header format) for the SAP solution.
Is there any way to make the F5 Big-IP Proxy Protocol Initiator for version 2?
04-Jun-2020 08:47
I have no experience on that, but I find this:
https://support.f5.com/csp/article/K40512493
http://www.haproxy.org/download/1.8/doc/proxy-protocol.txt
https://github.com/ably/proxy-protocol-v2
Are you working with IPv4 and TCP ?
Maybe this:
# Protocol signature
set headerHex "0d0a0d0a000d0a515549540a"
# As Local
append headerHex "20"
# IPv4 and TCP
append headerHex "11"
# Length 22
append headerHex "0c00"
# Source IPv4 as Hex
foreach oct [split [IP::remote_addr] "."] {
append headerHex [format %02x $oct]
# Dest IPv4 as Hex
foreach oct [split [IP::local_addr] "."] {
# Source port as Hex
append headerHex [format %04x [TCP::remote_port]]
# Dest port as Hex
append headerHex [format %04x [TCP::local_port]]
# Write header as byte
TCP::respond [binary format H* $headerHex]
Please, permit me to be wrong with that example code when it is just a shot.
If necessary, I think you can run proxy-protocol-v2 as node.js libraries in iRuleLX.
Kind regards.
04-Jun-2020 21:36
Hi, thanks for your answer.
I tried your iRule, but with that enabled there is no communication at all.
We are using https virtual server. As we do not want to terminate the SSL traffic on the F5, we can't use the x-forwarded-for. That's why we wanted to use proxy protocol. (which is working fine from F5 side for v1, but SAP side does only support v2).
I'm happy about any other opinions or ideas.
Kind regards.
05-Jun-2020 02:05
05-Jun-2020 02:08
I did, but this is for proxy protocol receiver. What I need is the F5 to be the Initiator, so to provide the end-system with the actual client IP address, and not to receive proxy protocol messages.
05-Jun-2020 02:30
Can you please share your vip configuration details and the iRule details so that we can see the issue closely.
Also are you using RabbitMQ instances
If yes then you need
To enable this support on an F5 LTM, perform the following steps:
Enable proxy_protocol on your RabbitMQ instances.
{rabbit,[
{proxy_protocol, true}
On the F5 appliance, create an iRule with the following contents:
https://devcentral.f5.com/codeshare/proxy-protocol-initiator
Apply this iRule to your AMQP Virtual Server(s). Note, this does require a TCP profile to be applied, so a 'Standard' Virtual Server will need to be used.
That's it! You should now see your client connection information!
Without Proxy Protocol enabled
(This IP is within the snat pool on the virtual server)
05-Jun-2020 02:35
