10-May-2007
06:40
- last edited on
01-Jun-2023
10:23
by
JimmyPackets
I'm building an iRule on a vip with serverside-ssl. The iRule must validate the common name in the server-certificate dynamically against the Host: header in the http-request. If the cn doe not match, the iRule should terminate the ssl-session on the server-side and give a http-error-response on the client-side.
Here is what I have so far:
set hostname [HTTP::host]
when SERVERSSL_HANDSHAKE {
set sslcert [SSL::cert 0]
set cn [findstr [X509::subject $sslcert] "CN=" 3]
if { $cn ne $hostname } {
reject
log local0. "Connection closed $cn != $hostname"
I want to make sure that the initial http-request does not get forwarded to the back-end-server before I terminate the connection, so using the HTTP_RESPONSE event to give the error-message is not an option. Unfortunately I can't use "HTTP:respond" in the SERVERSSL_HANDSHAKE event.
Is there a way to close the SSL-session on the serverside *before* the client-request is forwarded to it, while keeping the client-connection open to provide an http-error-response?
I also tried LB::detach, but then the connection stalls. Is ther a way to turn back to the client-connection after the LB::detach command?
Cheers,
Sake
10-May-2007 09:07
Kevin
10-May-2007
09:14
- last edited on
01-Jun-2023
10:23
by
JimmyPackets
That's what I thought too. But unfortunately this is not the case in the server-side ssl-connection. I added an iRule that logs an entry on every event and this is what the logging looks like:
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in CLIENT_ACCEPTED
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in HTTP_REQUEST
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in LB_SELECTED
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in SERVER_CONNECTED
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in HTTP_REQUEST_SEND
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in SERVERSSL_HANDSHAKE
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in HTTP_RESPONSE
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in SERVER_CLOSED
May 10 11:09:37 tmm tmm[12822]: Rule rule_event : in CLIENT_CLOSED
Cheers,
Sake
10-May-2007 12:18
Kevin
11-May-2007
11:28
- last edited on
01-Jun-2023
10:22
by
JimmyPackets
You might try using "LB::detach" to close the server side of the connection without affecting the client side:
LB::detach
log local0. "Server-side connection closed: $cn != $hostname"
HTTP::respond 200 content "blah"
HTH/deb
