Dazzla_20011
Apr 01, 2011Problem with website Pool using port 443
We've set up this new UAT website to only use https so the pool members are load balancing using port 443. The health monitor I've created is also using https. Everything looks fine as the Pool members are green but I'm not able to access the website using the Virtual Server, it just seems to timeout. Just wondered what steps I can take on the F5 to troubleshoot this as I can access the site fine if I connect directly to the webservers?
Darren
Sort By
- markj_58101
Try run a tcpdump on ingress & egress of the LTM, this will tell you if the LTM is stopping the traffic (likely to be a config issue) or if the server is not responding. - Dazzla_20011
Sorted, realised I had to apply the server-side ssl profile to the Virtual Severs. - Yes sir, you're going to need to re-encrypt that traffic.. ;)
