yogipd's avatar
yogipd
Sep 29, 2023
Print GTM pool and loadbalacing method for all pools in GTM
Hello,
we are having more than 800 WIP in GTM and I need to print the WIP, and Loadbalacing method for pool members.
example
GTM WIP: aaa.wip.com (roundrobin), Pool: Prefered( Global avilability)
I need the out put something like this:
aaa.wip.com- Global availability
I tried the following from articles but doesn't seem to be working
show pool all | grep "pool-lb mode\|Pool:"
tmsh list gtm pool all load-balancing-mode
    Hi yogipd
    I guess you are missing a after pool keyword, use the command like this
    check if small a or capital A after pool keyowrd will work.
    tmsh
    list gtm pool a all load-balancing-mode
    tmsh show gtm wideip a all detail | grep 'WideIp\|Destination'
    The following command will find pools with a return to DNS option and print the name of the pools.
    tmsh -c 'cd /; list gtm pool recursive all-properties one-line' | awk '/return-to-dns/{print $4}'
    My Other GTM master Commands which i use frequently and keep customizing them based on the requirement and then pul them in excel sheet and then use DATA  TAB, and there is one option text to columns
    And use  Delimited radio button and run the Wizard to convert F5 Command output text command output to mulitple colums for easy readability.
    My Other GTM master Commands you can try to get more results of your choice
    bash mode
    netstat -na |grep 4353
    tmsh list /gtm server all
    tmsh list gtm wideip a one-line
    tmsh list gtm wideip aaaa one-line
    tmsh show gtm wideip a detail
    tmsh show gtm wideip a pools
    tmsh show gtm listener
    tmsh show gtm listener all-properties
    tmsh show gtm pool a detail
    tmsh show gtm pool a detail field-fmt
    show gtm pool a members detail
    show gtm pool a members fireld-fmt
    show gtm pool a members field-fmt server
    show gtm server all detail
    show gtm server detail virtual-servers
    show gtm server detail virtual-servers field-fmt
    list gtm server addresses virtual-servers
    show gtm server detail all
    list net self all-properties
    list gtm listener all-properties
    list gtm listener vlans
    show sys ip-address all-properties
    tmsh show gtm wideip A all detail | grep 'WideIp\|Destination'
    tmsh show gtm all detail | grep -e -i Gtm::Server -e "Server"
    show gtm wideip a all detail | grep -e -i -n NAME_OF_YOUR_GTM_SERVE
    show gtm wideip a all detail | grep -i -e Gtm::Pool::A grep -i -e 'Pool\|Destination'
    show gtm wideip a all detail | grep -i -e Gtm::Pool::A grep 'Pool\|Destination'
    show gtm wideip a all detail | grep -i -e Gtm::Pool::A | grep -i -e 'Pool\|Destination' grep -i -e 'Pool\|Destination'
    show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e Gtm::Pool::A grep -i -e 'Pool\|Destination'
    only one pipe
    show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e NAME_OF_YOUR_GTM_SERVER
    show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e 'NAME_OF_YOUR_GTM_SERVER$'
    show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' | grep -i -e '^NAME_OF_YOUR_GTM_SERVER$' = No results
    show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e '\^NAME_OF_YOUR_GTM_SERVER$'
    show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e '\^NAME_OF_YOUR_GTM_SERVER$'
    show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e '^NAME_OF_YOUR_GTM_SERVER$'
    show gtm wideip a all detail | grep -i -e '^NAME_OF_YOUR_GTM_SERVER$'
    show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e '\NAME_OF_YOUR_GTM_SERVER'
    show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -e -i Gtm::Server -e "Server" grep -i -e '\NAME_OF_YOUR_GTM_SERVER'
    show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -e -i Gtm::Server -e "Server" grep -i -e '$NAME_OF_YOUR_GTM_SERVER'
    show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -e -i Gtm::Server -e "Server" grep -i -e '$*NAME_OF_YOUR_GTM_SERVER' -C 2
    show gtm wideip a all detail | grep -i -e '$*NAME_OF_YOUR_GTM_SERVER' -C 1
    show gtm wideip a all detail | grep -i -e '$*15*' -C 1
    show gtm wideip a all detail | grep -i -e '$*gtm*' -C 3 grep -i -e '$*NAME_OF_YOUR_GTM_SERVER'
    show gtm wideip a all detail | grep -i -e '$*gtm*' grep -e -i NAME_OF_YOUR_GTM_SERVER
    gtm pool a (f5.com)
    HTH
    F5 Design Engineer
    ๐Ÿ™
    โ€ƒ
