10-Aug-2022 00:56
We have multiple web applications running on a single Virtual server with host/domain based pool routing.
For eg:
red.lab.ae
blue.labe.ae
irule:
switch [string tolower [HTTP::host]] {
red.lab.ae {
pool Red_Pool1 }
green.lab.ae {
pool Green_Pool1 }
Please let me know how to prevent banner gradding for only specific domain (for eg: green.lab.ae) in F5
10-Aug-2022 02:45
I have the same problem with facing same issue but no response from anyone and couldn't find this topic troubleshooting in search engine.
24-Aug-2022 08:34
Did @JoshBecigneul's comment above help?
10-Aug-2022 18:43
Hi @Preet_pk
If I'm understanding your question correctly, one option could be to add a default branch to the switch statement and then call either the drop or reject commands. Another way would be to use HTTP::respond and send back a 404 Not Found which might be better for troubleshooting purposes.
Thanks,
Josh
11-Aug-2022 07:14
Can you share complete irule syntax so as to test it.
24-Aug-2022 12:03
Hi @Preet_pk
That would look something like this with the addition of the default option. I commented the other two options. More info on the switch operator is here: https://clouddocs.f5.com/api/irules/switch.html
red.lab.ae {
pool Red_Pool1
green.lab.ae {
pool Green_Pool1
default {
drop
# reject
# HTTP::respond 404 content "Not Found" noserver
