Technical Forum
Custom Alert Banner
Portal Access question
cd
Cirrus
Cirrus
Hello, I've a question about Portal Access
I have one single VS with APM and we have multi branchs in the VPE. Each branch have a different Portal Acess/Webtop so we can have many applications on the same VS with different URIs (https://portail.siteweb.fr/app1 https://portail.siteweb.fr/app2 etc...)
But the problem is with this unique VS I'm obligated to have a general rewrite/web Acceleration profile applied to the VS
So my question is how can I use different web acceleration profils and rewrite profils for different Portal Access in the same VS ? Is this possible ?
1 REPLY 1
When you create Web-Acceleration profile, you can customize it and apply profile to specific URI. So with this, you can achieve your requirement. For rewrite, I haven't completely played around with this but you can try once if you can achieve your requirement using polices, or settings under rewrite profile itself.
Mayur
