Glenn_32974's avatar
Glenn_32974
Jan 09, 2012
POP3 over SSL/TLS monitoring
Hello
I would like to know what would be the recommended way to monitor POP 3 servers over SSL/TLS since default POP3 monitor does not generate SSL traffic ?
would this only be possible with an irule?
any comments highly appreciated
rgs
  • i never tried but thinking external monitor using command such as openssl might be usable.
    anyway, there is request for enhancement which is targeted in later release.
    ID248016 - RFE: Add Security param to POP3/IMAP monitor allowing SSL/TLS selection (Formerly CR 141398)
