Pool Statistics
Jo_31162
In a Viprion system I've configured a VS with two nodes in a pool.
After, I've set the connection limit to each node to 1500 but in the pool statistics menù, the maximum connection for each node stop to 750.
Why?
Thanks in advance
12 REPLIES 12
nitass
F5 Employee
F5 Employee
have you seen this one?
sol8457: Connection limits configured on pool members or nodes within a Clustered Multi-Processing configuration are incorrectly enforced per TMM instance
http://support.f5.com/kb/en-us/solutions/public/8000/400/sol8457.html
hope this helps.
Jo_31162
Yes but I 've Release 11.1.0, not 9.6.x
nitass
F5 Employee
F5 Employee
Yes but I 've Release 11.1.0, not 9.6.xthe solution is applied to up to 11.2.1. the 9.6.0 and 9.6.1 issue is each blade (instead of each tmm) incorrectly performs connection limit.
Jo_31162
So, It's a bug....right?
What_Lies_Bene1
On VIPRION the connection limit should apply per blade. Are these nodes in any other Pools? Perhaps you could change the connection limit to 3000 and apply it to the Pool rather than the Nodes.
nitass
F5 Employee
F5 Employee
So, It's a bug....right?yes, it is.
Jo_31162
I've just one blade. Each node is in three different pools and I must use connection limit on the node...
Jo_31162
Nitass, What Lies Beneath,
thanks for your quick answers but I need to summarize...
It's a single blade and the pool statistics menù show 750 connections per node instead of 1500 per node.
Can I say..."You need to update the Viprion to solve this issue" ?
Hamish
Cirrocumulus
Cirrocumulus
Iirc that bug hasn't been fixed yet has it?
From memory, the way its doing things is dividing the number of connections max by the number of tmm's on the blade... So you get 750 per tmm...
H
nitass
F5 Employee
F5 Employee
sorry i think i was wrong. sol8457 should not be the case. i was able to get a number of connection limit i set.
[root@c2400:/S1-green-P:Active:Standalone] config tmsh show sys version Sys::Version Main Package Product BIG-IP Version 11.2.0 Build 2451.0 Edition Hotfix HF1 Date Tue Jun 5 23:45:09 PDT 2012 Hotfix List ID387964 ID387843 [root@c2400:/S1-green-P:Active:Standalone] config tmsh show sys tmm-info|grep -i sys\:\:tmm\: Sys::TMM: 1.0 Sys::TMM: 1.1 Sys::TMM: 1.2 Sys::TMM: 1.3 Sys::TMM: 1.4 Sys::TMM: 1.5 Sys::TMM: 1.6 Sys::TMM: 1.7 root@(c2400)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 100.100.100.100:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { tcp { } } snat automap vlans-disabled } root@(c2400)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } 200.200.200.111:80 { address 200.200.200.111 } } } root@(c2400)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) list ltm node 200.200.200.101 ltm node 200.200.200.101 { address 200.200.200.101 connection-limit 40 } root@(c2400)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) list ltm node 200.200.200.111 ltm node 200.200.200.111 { address 200.200.200.111 connection-limit 40 } on client ab -n 100 -c 100 http://100.100.100.100/ This is ApacheBench, Version 2.0.40-dev <$Revision: 1.146 $> apache-2.0 Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/ Copyright 2006 The Apache Software Foundation, http://www.apache.org/ Benchmarking 100.100.100.100 (be patient)... Test aborted after 10 failures apr_socket_connect(): Connection reset by peer (104) on bigip [root@c2400:/S1-green-P:Active:Standalone] config tmsh show ltm node 200.200.200.101 | grep -i maximum Maximum Connections 40 - [root@c2400:/S1-green-P:Active:Standalone] config tmsh show ltm node 200.200.200.111 | grep -i maximum Maximum Connections 40 -
Jo_31162
If I remember well, Viprion 2100 blade include:
8 TMM istances and 1 TMM process per hyperthreaded core.
So, what is the correct computation?
Jo_31162
Good morning,
any final answer regarding this issue?
Thanks to all
