Dmitri_Ch__1425's avatar
Dec 11, 2014
Please, help me understand hardware specs for LTM devices...
http://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf (5200 platform)
could you please help to clear following numbers for me?
L7 requests per second: 1.5M
  • Is it standard VS ? (full reverse proxy, i.e., SYN-ACK-SYN with client and then SYN-ACK-SYN with node)
L4 connections per second: 700K
  • is it Performance L4 VS ? (with SYN-ACK-SYN from client to node, hence 1/2 of L7 value)
Maximum L4 concurrent connections: 24M
  • OK
L4 HTTP requests per second: 7M
-? Performance L4 VS /w HTTP profile?
Throughput: 30 Gbps/15 Gbps L4/L7
  • max Throughput device can handle ?
SSL: Included: 21,000 TPS (2K keys) ?
Maximum: 21,000 TPS (2K keys) ?
  • SSL TPS?
Where do connections from nodes fall in, in case when F5 used as default Gateway? Technically it's using L4 VS /w 0.0.0.0 destination, so it's probably under L4?
THANK YOU.
