Technical Forum
Please help: LTM model with SSL acceleration hardware
ST_Wong
Altostratus
Altostratus
Hi there,
Is there a complete list of LTM model with SSL acceleration hardware included?
Thanks a lot.
Best Regards
1 ACCEPTED SOLUTION
4 REPLIES 4
Mike757
MVP
MVP
Hi ST,
I believe all current hardware platforms have dedicated hardware for SSL: You can compare them here:
Appliances: https://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
VIPRIONs: https://www.f5.com/pdf/products/viprion-overview-ds.pdf
Mike
ST_Wong
Altostratus
Altostratus
Hi Mike,
Thanks for your help.
Too bad that we still have some aged LTM (3900, 6400) . We'd like double check if they're hardware SSL capable platforms, which will need special handling before disposal (due to export control of SSL acceleration hardware :).
Best Regards
/ST
Mike757
MVP
MVP
Yeah, those are old... but google is your friend:
https://wtit.com/f5-products/f5-big-ip-1600-3600-3900-hardware-datasheet/
https://www.f5.com/pdf/products/big-ip-platforms-2007-ds.pdf
They both have SSL hardware.
Mike
ST_Wong
Altostratus
Altostratus
Got it. Thanks Mike.
