Tosin_Omojola
Jul 10, 2014Altostratus
Platform upgrade from 11.2.1 - 11.4.1 Error
Please I need some help here. I upgraded a strongbox from 11.2.1 - 11.4.1 in order to deploy the AAM module on it. After the upgrade, the system rebooted and came up with this error message: "The configuration has not yet loaded. If this message persists, it may indicate a configuration problem" The message prevented me from making any configuration because the needed files were not loaded. I rebooted the machine with the intent to revert to the former version (11.2.1).
After reboot, I found out that the system keeps initializing after I set the mgt IP for admin access. It continues to initialize and wiping off the mgt IP settings. Please, I would appreciate some help regarding this issues.
Thanks in advance.
