Technical Forum
Persistence Pool Member
Lloyd-Mc
Hi there,
I am trying to implement a canary deployment for my business' applications.
To do this I have the following:
Pool A
Node1 - ratio 4
Node2 - ratio 4
Node3 - ratio 4
Node4 - ratio 4
CanaryNode1 - ratio 2
I am currently using an iRule to route traffic to respective pools. Is there a way to set up persistence but just for the canary node? Or can I distribute traffic to 2 pools with a ratio through an irule - one pool a canary and the other containing standard nodes?
The standard nodes cannot be persistent.
Any help would be much appreciated.
0 REPLIES 0
