Persistence Not Working
genseek_32178
For the following VIP, persistence is not working..
virtual syz-443
pool syzpl-443
destination 20.20.12.25:https
ip protocol tcp
vlans 25 enable
profiles tcp-profile
persist persist-source-addr-syz
http://20.20.12.25/lb/on.txt is giving different server every minute when persistence is set to 600 sec.
any help here would be great on what is causing this?
genseek
5 REPLIES 5
MVA
Just taking a quick look at your posted config, it seems as though your destination is https but the URL you posted is http. Is there another Virtual Server using http without persistence?
genseek_32178
yes there is another VS that is using http with persistence.
genseek_32178
i noticed the following also..
persist-source-addr-syz - IS the custom profile...AND
persist-default-syz - Is the default profile
Although, the persist-source-addr-syz is set for timeout vlaue of 600,
the persist-default-syz profile seems to be having no setting of timeout value
b profile persist-default-syz list
defaults from sourceaddr
As no timeout setting is defined the custom profil persist-source-addr-syz , must be inheriting timeout settings from the parent profile.
and therefore persistence is not sticking till 600 secs.
Could this be the reason?
genseek_32178
nitass, any updates?
genseek_32178
the working VIP1 is runing on 10.2 and non-working VIP2 is running on 9.4
