28-Apr-2020 18:08
Hi all
Trying to establish the best way to achieve a Transparent proxy pool on an F5 VIP if it is possible.
Essentially want webtraffic directed to the F5 to be load balanced to a pool of transparent proxies.
Router doing Policy Based routing to send any LAN TRAFFIC 80+443 traffic to a VIP on an F5. This i would require PBR on the F5 as well as the VIP is advertised from a selfIP on the F5.
Even with both PBRs in place is this something that is achievable on the F5?
what type of VIP would be required for this?
HOST: 1.1.1.1 [website.com 5.5.5.5:80]
1.1.1.1 >> 1.1.1.2
RTR: 1.1.1.2 [PBR - 1.1.1.1 DST 80 nexthop set 3.3.3.3]
2.2.2.1 >> 2.2.2.2
F5: 2.2.2.2 [PBR - 1.1.1.1 DST 80 nexthop set 3.3.3.3]
2.2.2.2 >> 3.3.3.3
F5: 3.3.3.3 [VIP with Transparent Proxy Pool 4.4.4.0l]
29-Apr-2020 22:38
The BigIP lets you create 0.0.0.0:80/0.0.0.0:443 fastl4 listeners that captures all traffic with a destination port of 80/443 that is sent to the floating self-IP (i.e as a gateway) (that does not match a more specific listener).
The listeners then forward the traffic to the pool of proxies (with or without address translation as required).
