neeeewbie's avatar
Feb 23, 2021
other memory usage high on 15.0.1
Hi guys
I need your help..
our customer using i2600 and 15.0.1 OS, starting from install this device "other memory" usage increase slightly .. now other memory usage almost 90%!
specifically anonpages has high usage .. I don't know why "other memory" has high usage
please let me know if you have documents relate to this problem
thank you!
  • Hi neeeewbie,
    There may be many reasons for this. v15.0.x is EoDS and EoTS.
    https://support.f5.com/csp/article/K5903
    Bug Tracker: https://support.f5.com/csp/bug-tracker
    I suggest you upgrade to v15.1.x. (Currently v15.1.2.1)
    https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/related/relnote-supplement-bigip-15-1-2-1.html
    • neeeewbie's avatar
      neeeewbie
      Icon for MVP rankMVP
      Hi I found Bug ID
      https://cdn.f5.com/product/bugtracker/ID809597.html
      we using SSLO license and this license need APM. so, this bug occurred
