Gregory_Gerard_'s avatar
Gregory_Gerard_
Apr 30, 2008
Oddities in XForwardedFor?
I'm using Tomcat as a webserver and I've got access logs recording the XForwardedFor header into the log.
The oddity I'm seeing is this:
10.20.108.103,unknown
My internal network is 10/16 but *not* 10.20!.
Why is the LTM not recording the real IP address of the other side which is what I really need in the access log?
For most entries, everything works grand but it's these anomalies that are driving me nuts.
The other puzzler is why the LTM even acknowledges the packet.
10. is not publicly routable and this is coming in off a publicly routed interface. I would presume (perhaps wrongly) the LTM would filter out "funny" traffic.
thank!
  • Hi,
    Have you tried to create an iRule to check this ?
    for example:
    when HTTP_REQUEST_SEND {
    log local0. "request from [IP::client_addr] with X-FORWARDED-FOR value: [HTTP::header "X-Forwarded-For]"
    Then you check your log in /var/log/ltm for the logging result. It should help you !
    Ensure to write properly the name of the HTTP header X-Forwarded-For
    HTH
  • I will add this to my rules but I'm not sure when it will happen again.
    Thanks for the suggestion on the diagnostic, though.
    I just don't see how this is happening though. The LTM is directly attached to the ethernet and IP space from the colo -- nothing to get in the way!
  • hoolio's avatar
    hoolio
    It's possible that a client or previous network device is inserting an XFF header. It's also possible that the BIG-IP is inserting an invalid value (bug?). nmenant's example should help you determine what's happening. If you get a runtime error from the example when trying to use the HTTP::header command in the HTTP_REQUEST_SEND event, you could try forcing the HTTP::header command into the clientside context using 'clientside {HTTP::header "X-Forwarded-For"}'.
    If you are using the client IP address for anything more important than reporting, it would be good to use an iRule to remove any existing instances of the header you're going to insert before you actually insert the new header. Here's an example:
        Remove all instances of the custom header
       while {[HTTP::header exists X-Forwarded-For]}{
          HTTP::header remove X-Forwarded-For
        Insert a new XFF header with the client IP address as a value
       HTTP::header insert X-Forwarded-For value [IP::client_addr]
    Aaron
  • Thanks, Hoolio! That's neat.
    Now, the question is, how is this different from checking the checkbox in the profile (Insert XForwarded For ...)?
  • hoolio's avatar
    hoolio
    The HTTP profile option would just add a new XFF header with the client IP address. It wouldn't touch any existing XFF headers.
    The XFF header LTM inserts would be the last XFF header in the request and in theory this is the one the server should parse for its logging.
    The iRule ensures that no prior XFF headers are included in the request sent to the server.
    Aaron
  • Thanks for the quick feedback Hoolio!
    So, I leave the http profile as it is (with the Insert XFF option enabled) and add this iRule to the virtual server right?
    Manuel
  • hoolio's avatar
    hoolio
    The rule will remove all existing instances of the XFF headers and insert one, so you do not need to enable the XFF option on the HTTP profile.
    Aaron
