Technical Forum
Novice Question - irules
kirkpabk
Altostratus
Altostratus
This is a quick novice question--does the F5 platform come with irule capability by default? Or does it need to be added, licensed or otherwise enabled first?
1 ACCEPTED SOLUTION
PeteWhite
F5 Employee
F5 Employee
yes, the default comes with iRules. But iRulesLX which is based on Node.js is not enabled by default - it is licensed and provisioned
2 REPLIES 2
PeteWhite
F5 Employee
F5 Employee
JRahm
Community Manager
Community Manager
@kirkpabk@PeteWhite is 100% here, so I marked this solution as correct. One caveat: there is functionality (some commands and events) that is licensed module specific, so those particular features within iRules will not work by default, you have to be licensed for each of those specific modules to unlock them.
