Technical Forum
Not receive 'Set-Cookie' data from the response header in F5 14.0.0
sankarkiran
I calling F5 through Java code via httpClient. Here is my code
HttpClient httpClient = trustEveryoneSSLHttpClient();
HttpPost authenticatePost = new HttpPost(getAuthenticationUrl());
authenticatePost.addHeader("Content-Type", "application/json");
authenticatePost.addHeader("Authorization", "Basic " + Base64Coder.encodeString(username + ":" + password));
HttpResponse authResponse = httpClient.execute(authenticatePost);
But in the authResponse I am not getting Set-Cookie data on the headers array.
I am using F5 14.X version.
Can you please help me to resolve.
2 REPLIES 2
whisperer
Cumulonimbus
Cumulonimbus
Are you expecting to receive a cookie pashrough from the application or are you expecting the F5 BIGIP to perform the persistence management and provide the cookie? Have you tested against the server from the F5 via curl to see if you receive a cookie?
Paulius
MVP
MVP
@sankarkiran Have you tried running an tcpdump to see if the server is indeed sending the cookie and the F5 is receiving it?
