Goran_Blomquis1's avatar
Goran_Blomquis1
Dec 22, 2017
No output from persist lookup $header1
Hi all,
We have a case there we need to investigate and take decision based on persistence record.
I do a set ins_id to read header that also is used in persistent table. Persistent work and I have value in table when look in persistence table via TMSH. So it's OK. Problem is that I can´t get any value in log from "persist lookup uie" part.
set inst_id [HTTP::header value "installationId"] set pvaleu [persist lookup uie $inst_id] if {$host_debug}{log local0. "$log_prefix: installationId = $inst_id and pvaleu = $pvaleu"}
When I look in log it´s looks like this:
Dec 22 12:26:26 lbt_bgc_a1 info tmm1[28894]: Rule /Common/i-rule_d171222 : client IP:port=213.115.83.54:29873; VIP=/Common/: installationId = 48548FBCB1BB4D1780C3E7D18C3FD9C5 and pvaleu =
So I do not get any output from "set pvaleu [persist lookup uie $inst_id]" in LTM log.
Best Regards and Have a Great Christmas
//Goran
  • https://devcentral.f5.com/wiki/irules.persist.ashx
    "persist lookup [all|node|port|pool] "all" or no specification returns a list containing the node, port and pool name. Specifying any of the other return types will return the specified item only. = | { [any virtual|service|pool] [pool ] } the latter key specification is used to access persistence entries across virtuals, services, or pools."
    Try to add the virtual server or pool in the lookup command. The link has multiple examples.
  • this is mine. big-ip is running 12.1.2.
    // config
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual baz
    ltm virtual baz {
        destination 10.200.155.165:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        source-address-translation {
            type automap
        translate-address enabled
        translate-port enabled
        vs-index 3
    root@(bip1a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
    ltm rule qux {
      log local0. "\[HTTP::cookie SESSION\]=[HTTP::cookie SESSION]"
      if { [HTTP::cookie SESSION] ne "" } {
        log local0. "persist lookup uie [HTTP::cookie SESSION]=[persist lookup uie [HTTP::cookie SESSION]]"
        persist uie [HTTP::cookie SESSION]
    when HTTP_RESPONSE {
        persist add uie [HTTP::cookie SESSION]
    // client
     curl -I http://10.200.155.165
    HTTP/1.1 200 OK
    Date: Fri, 22 Dec 2017 20:48:25 GMT
    Server: Apache/1.3.26 (Unix) PHP/4.1.2 mod_ssl/2.8.10 OpenSSL/0.9.6b
    X-Powered-By: PHP/4.1.2
    Set-Cookie: SESSION=a83ccc31492529e8cd457417befb5e59; path=/
    Expires: Thu, 19 Nov 1981 08:52:00 GMT
    Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
    Pragma: no-cache
    Content-Type: text/html
     curl -I http://10.200.155.165 -H "cookie: SESSION=a83ccc31492529e8cd457417befb5e59"
    HTTP/1.1 200 OK
    Date: Fri, 22 Dec 2017 20:48:41 GMT
    Pragma: no-cache
    // big-ip
    [root@bip1a:Active:In Sync] config  tail -f /var/log/ltm
    Dec 22 21:32:01 bip1a info tmm[12155]: Rule /Common/qux : [HTTP::cookie SESSION]=
    Dec 22 21:32:01 bip1a info tmm[12155]: Rule /Common/qux : [HTTP::cookie SESSION]=a83ccc31492529e8cd457417befb5e59
    Dec 22 21:32:17 bip1a info tmm[12155]: Rule /Common/qux : [HTTP::cookie SESSION]=a83ccc31492529e8cd457417befb5e59
    Dec 22 21:32:17 bip1a info tmm[12155]: Rule /Common/qux : persist lookup uie a83ccc31492529e8cd457417befb5e59=/Common/foo 10.200.155.166 80
  • Thanx for replay both of you.
    There was some Christmas and a new year, some other assignments between, so that´s why my feedback have been delayed. I did some redesign so I did not have to use "lookup" command, did not get it to work in the event I needed it. Insted I used a Universal Persistense profile on both virtual servers. Persist profile use "Match Across Virtual Servers" and desired timeout.
    Used persist add to add persistence in response header on first vip and then used persist on URI to use same backend with the same value used in response header in other VIP.
    I-rule looks somthing like.
    set persist_uri [string tolower [HTTP::uri]]
    switch -glob $persist_uri {
        "*/example1/content/*" {
            set reference_example1 [findstr [HTTP::uri] "/example1/content/" 18 32]
            persist uie $reference_example1
            log local0. "$Persist on $reference_example1"
        "*/example2/content/*" {
            set reference_example2 [findstr [HTTP::uri] "/example2/content/" 18 32]
            persist uie $reference_example2
            log local0. "Persist on $reference_example2"
        if { [HTTP::header exists "Referense_Header"] } {
            set reference_token [HTTP::header value "Referense_Header"]
            persist add uie $reference_token
            log local0. "Persist record in PaymentRequestToken Header , payment reference = $payment_token"}
    (Pool selection and all other logic is done in I-rule attached to VIP).
    Works perfect in my case!
    Regards
    //Goran
