Mike_Ho
Jul 24, 2020Cirrus
Network access connection rejected by ACL is completing 3-way handshake?
I'm running 13.1.3.4 and creating a network access tunnel with an ACL applied. There's a L4 ACE to Reject traffic to a given IP. When I monitor on my VPN interface (on Windows and Mac) I see a full 3-way handshake succeed to that IP ???, followed by a TCP RST. When I set the ACE to Discard I see the same behavior. Can someone explain how this is a feature?
If I monitor for packets on the BigIP I don't see the packets actually passing through to the blocked IP, so I assume this is a BigIP "feature". Any info is welcome. Thanks,
Mike
