Technical Forum
Custom Alert Banner
Need to forward traffic on specific pool according to uri over 500 urls
Amit787
Hello
I am having requirement to setup new url "example.com" and when user try to access
"example.com/user1" traffic should be on "pool1"
"example.com/user2" traffic should be on "pool2"
"example.com/user3" traffic should be on "pool3"
"example.com/user500" traffic should be on "pool500"
Need dynamic way to achieve this, instead of writing 500 lines of code.
Please advice.
Thanks,
Amit
3 REPLIES 3
Hi Amit,
Can you try this iRule?
	if { [HTTP::host] equals "example.com" && [HTTP::uri] matches_regex {\/user[0-9]{1,3}} } {
		set poolID [string trimleft [HTTP::uri] "/user"]
		set poolname "pool$poolID"
		# log local0. "poolname: $poolname"
		pool $poolname
Amit787
Thanks you sooo much "eaa". Solution worked.... 🙂
Amit787
And thanks a lot for your quick support as well... ​
