27-Aug-2021 10:00
I need to delete specific cookie from client browser when APM session is closed. I found https://devcentral.f5.com/s/question/0D51T00006i7cT0/hot-to-delete-a-particular-cookiejsessionid-when-accesssessionclosed-event-is-trigered but looking on ACCESS_SESSION_CLOSED description it loos like "The iRule commands which require a flow context (for e.g. TCP, HTTP and SSL commands) can not be used in this event".
Indeed, if I am trying iRule from other topic:
when ACCESS_SESSION_CLOSED {
HTTP::cookie expires "JSSIONID" 0 absolute
HTTP::cookie expires "LtpaToken2" 0 absolute
It gives me error "command is not valid in current event context ".
Any help will be greatly appreciated.
27-Aug-2021 12:34
Hello Dmitriy.
Try this code:
HTTP::header insert "Set-Cookie" "MyCookie=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/"
Regards,
Dario.
30-Aug-2021 08:34
Thank you for suggestion, Dario but it is the same problem. When I am trying to create suggested iRule, F5 tells me: command is not valid in current event context (ACCESS_SESSION_CLOSED)][HTTP::header insert "Set-Cookie" "MyCookie=deleted;expires=Thu, 01-Jan-1970 00:00:01 GMT;path=/"]
It is pretty much aligned with what documentation says about ACCESS_SESSION_CLOSED event The iRule commands which require a flow context (for e.g. TCP, HTTP and SSL commands) can not be used in this event"
30-Aug-2021 08:37
Still looking for the possible solution. Any help will be greatly appreciated.
30-Aug-2021 11:15
Hi Dmitriy,
Can you try this iRule?
when CLIENT_ACCEPTED {
set status 0
set status 1
when HTTP_RESPONSE_RELEASE {
if { $status } {
01-Sep-2021 12:45
HI Enes,
Thank you for suggestion. I will look into your suggestion.
