Technical Forum
Custom Alert Banner
Need help. What is exc?
SeanM
When using this syntax, what is "exc" and what does it do?
if { [catch {pool $hostpool} exc] } {
1 ACCEPTED SOLUTION
Samir
MVP
MVP
Here exc is exception handling in the pool assignment request.  catch - Evaluate script and trap exceptional returns.
catch script ?varName?
The catch command is used to prevent errors from aborting command interpretation. The catch command calls the Tcl interpreter recursively to execute script, and always returns without raising an error, regardless of any errors that might occur while executing script.
Hope it will help you.
1 REPLY 1
Samir
MVP
MVP
