Technical Forum
Custom Alert Banner
Need Help to write Irule or LTM policy
Aj15
Altostratus
Altostratus
We have two version for URL
www.xyz.com/v17 to 20
www.xyz.com/v15 to 16
need built irule if request arrive for v15to 16 it should stay in DC F5
but if request arrive for v17 and above it should redirect traffic toward AWS node(VS and FQDN (AWS) node has been already configured on DC Ff )
1 REPLY 1
Looking at the use case in the question, it seems you want to redirect request based on the URI path. For this, you can match it during http request event using irule or LTM policy. I would recommend you to use LTM policy which will match the URI path at request and then under actions, request can be forwarded to the desired pool, virtual server etc. depending on your requirement. Just make sure about the desired SSL configurations on the VS.
Hope it helps!​
