rodrigo_Benzaqu's avatar
rodrigo_Benzaqu
Oct 03, 2006
Need Help to Migrate Rule from V4 to V9
Hi Guys,
I have to move the following Rule from v4.x to V9.x. I,m trying to use "case" instead of "if", but it´s giving me syntax error:
rule Cache_Fetch {
if (http_uri starts_with "/jm/pms" or http_uri starts_with "/cgi/pms/") {
use pool PMS_java
else {
if (http_uri starts_with "/jm/" or http_uri starts_with "/jms/" or http_uri starts_with "/servlet/" or http_uri ends_with "_JM
" or http_uri ends_with "_JSEA" or http_uri starts_with "/dwr/") {
use pool Java_Servers
else {
if (http_uri contains "/ml/") {
use pool SQL_Servers
else {
use pool static_server
thanks for your help,
Rodrigo
  • I'd use a switch statement myself...
      switch -glob [HTTP::uri] {
        "/jm/pms*" -
        "/cgi/pms/*" {
          pool PMS_java
        "/jm/*" -
        "/jms/*" -
        "/servlet/*" -
        "*_JM" -
        "*_JSEA" -
        "/dwr/*" {
          pool Java_Servers
        "*/ml/*" {
          pool SQL_Servers
        default {
          pool static_server
    I think I've got all of your starts_with and ends_with correct, but you should double check.
    Hope this helps...
    -Joe
