21-Mar-2023 23:46
Hello,
Need help on configuring an irule configuration to log the client ip address and also the username for a web application which is going through LTM.Thanks.
Regards,
22-Mar-2023 04:06
Hi @Moonotech,
We need more information on your current configuration for this application, do you have SSL? Does the request come from a firewall? where is the username present on the web page and what parameter use the application for store the username?
22-Mar-2023 04:19
Hello @Sebastiansierra
The client side is encrypted by the LTM but the the backend application does not have SSL.The user is prompted for a username and password on the web application.We want to capture the username (when its entered by the user and submitted) and also client IP address.
Traffis flow is from the user (no firewall) through the F5 towards the backend servers (Firewall present).
22-Mar-2023 04:51
Hi @Moonotech,
For this work you have to determine the variable where the user is located and the create the next irule:
#Check if the basic auth username is present
set user [HTTP::username]
log local0. "Ip client [IP::client_addr] + the user is: $user"
23-Mar-2023 03:13
I am also looking for this.
