25-Nov-2019 21:07
Hello everyone,
I am following the Keith Barker CBT nuggets video to create a lab in my local machine.
Can someone help me to download web servers (red, blue, green) OVA files ? or can some one share the link where i can download these files ?
Rejanish
25-Nov-2019 23:57
26-Nov-2019 22:09
Hi eaa,
Thank you so much for your help really you shed light on my path, i will be in touch with you to get more help on the course.
Rejanish
17-Aug-2022 03:25
hey,
you have mybe the server with ovf type?
please!!
thank you
18-Jan-2023 04:35
Thank you very much! And the Big-IP? Which version and which Vmware you used for the labs? Tks!
30-Dec-2019 10:18
Hi Everyone,
Good day!
Could you please help to send link on how to download the web servers OVA files (red, blue, green) with regards to Keith Barker CBT nuggets video to simulate a lab in my laptop.
Or can someone share a link where I can download these OVA files.
Thank you and Kind regards,
C Web
30-Dec-2019 10:37
Hi C Web,
I re-uploaded ova files:
https://we.tl/t-PA9860Xewo
26-Jan-2020 02:48
Hello eaa
can you please kindly share again? the transfer is expired
thank you
26-Jan-2020 23:53
28-Jan-2020 13:08
28-Jan-2020 13:08
eaa..Thank you!
14-Feb-2020 23:17
Could I ask you to re-upload it again please,
Thank you in advance
17-Feb-2020 21:38
02-Mar-2020 18:09
Reupload please.
16-Nov-2020 18:14
what is the password?
I can not login.
please, provide it
Thank you
17-Nov-2020 03:19
Hi chaivang,
https://drive.google.com/open?id=1zTXgniBm_kXzKMiuuTbIGaYaDCDCorSq
zip file has no password.
02-Mar-2020 18:09
Can I have a copy of these files?
29-Jan-2020
03:55
- last edited on
24-Mar-2022
02:13
by
li-migration
Thank You for the link. could you advise with the username and password for the VMs ?
Thank you and wish you a good day
11-Feb-2020 17:19
Hi Everyone,
All the above links are expired, Can someone help me to download web servers (red, blue, green) OVA files ? or can some one share the link where i can download these files ?
could you also advise with the username and password for the VMs ?
12-Feb-2020 00:42
12-Feb-2020 03:46
thank you very much eaa. it is very much appreciated. 🙂
02-Mar-2020 20:49
Hi Jackey,
03-Mar-2020 23:50
Hello Jackey,
Can you post your Virtual Server configuration? It may help to debug.
19-Apr-2020 01:50
Hi Lidev
I am same problem,,Attached my Vs configuration,,can u help me..
19-Apr-2020 01:51
19-Apr-2020 01:51
19-Apr-2020 02:38
am able to ping from local PC to Vs ip,,but when i try open in browser ,its show up error..some help me..pls
19-Apr-2020 23:20
Hi Vasim,
Did you assign an HTTP profile on you Virtual Server ?
20-Apr-2020 01:14
Hi Lidev,
Thanks for your reply
Problem gets solved by selecting Auto Map in SNAT menu..
None i am able to reach 192.168.1.177 through local PC browser
20-Apr-2020 01:18
Glad to hear that 🙂 please mark this question as solved.
09-Feb-2021 05:07
Hi Vasim,
can u explain why after enabling "Auto Map", the issue solved
09-Feb-2021 05:53
Hi Mostaf,
with Auto Map enabled, there is no more asymmetric routing.
SNAT ensure that the response returns through the BIG-IP system instead of through the default gateway.
Regard
09-Feb-2021 07:17
Thanks for your reply.
ok but this issue should be appeared at one arm solution only, where the servers terminated at another device such as "Data center firewall", but at two arm design the servers terminated at F5 and we don't need a SRC NAT,
my reply is correct or wrong?
09-Feb-2021 07:34
No, even in Two armed configuration, if the default gateway on your backend server isn't the F5 BIG-IP, you need to use Auto map.
more details here : https://techdocs.f5.com/en-us/bigip-14-1-0/big-ip-tmos-routing-administration-14-1-0/nats-and-snats...
09-Feb-2021 07:35
okay, thanks Lidev
